HELP my car wont start!!!
recenetly in the last week my car hasn't started twice..my voltage meter says theres 12-13volts still in the battery..and it tries turning over but the fan slowly spins and it sounds like theres not enough juice..and the tach goes in reverse when i try starting it..does anybody know whats causing this?
is it the msd distibitor or the ignition box. the msd box may be screwing your timing, had it happen to another guy on here last week. very similar problem and he took out the msd and it ran fine.
its the msd distribitor..
does it have the box also. like msd 6 or something like that. it sure sounds like something throwing the timing in the distribitor or the ingnition. yes u can test the starter or have it tested in the car. starter draw test.
http://mx.truveo.com/starter-draw-testMPG/id/4217065021
yes its on top..i just got it last august too :/ i hope its not that
but the weird thing is, last time when this happened, my batter had good voltage but after getting jumped, it started fine..
