Help!!!
Old 05-26-2011, 01:30 PM
Broken cable maybe? Check to make sure it's connected on both ends, then pull the tranny end and see if it's got the square cable end sticking out. If it is you can put a cordless drill on the end and spin it clockwise to see if it turns the speedo.
Old 05-30-2011, 09:40 PM
Jeepin's Avatar
Alright I couldn't figure out the speedometer and now I have another problem....all of a sudden the driver door doesn't want to open anymore I don't know if the lock is stuck or if it's the handle I tried from both inside and out any of u guys ever have this problem?????
Old 05-30-2011, 09:52 PM
Have you tried unlocking it with the key? I know it sounds simple, but had to ask.
Try holding the outside handle up and pushing in on the door at the same time, or get someone inside to pull in or push out on the door as you hold the handle up outside.
Worse case scenario, hold up on the outside handle while someone sits in the seat opposite side and gives the door a sharp kick from inside to pop it open.
Old 05-30-2011, 11:40 PM
Jeepin's Avatar
Thanks 1971BB427 ur the most reliable on this forum!!! I don't have the keys for the door lock just the ignition....ima have to get someone to help me so I can try the other strategies...lol
Old 05-31-2011, 11:40 AM
Don't try the others until you get a key to unlock the door lock.
Old 05-31-2011, 11:50 AM
walkingchaos's Avatar
may be the same thing my drivers door did. the top hinge starts to fail and it tilts the end of the door down. try pulling up hard on the outside door handle while pulling out on the door to lift it off the striker pin.
Old 05-31-2011, 06:27 PM
If the door panel is off there is a hole that you can unbolt the striker while the door is closed. I had this problem a couple weeks ago. Blast sand got down inside the latch. I luckily had the panels off and used a long prybar to push the latch down from the inside.
The lift and kick is actually consider THE way to do it.
Old 06-08-2011, 07:15 PM
Jeepin's Avatar
Thanks guys for all ur help I drove the car to Tx with no problems at all it all went perfect!!!!!!!
Old 06-09-2011, 08:19 AM
Nice! Good to be prepared and have a trip go that well! The car must be in pretty good shape to make the trip without a hitch!
