-   70-81 General (https://camaroforums.com/forum/70-81-general-12/)
-   -   HEI Corrected cap with MSD Ignition (https://camaroforums.com/forum/70-81-general-12/hei-corrected-cap-msd-ignition-62887/)
92 RS in training Jun 26, 2011 10:37 PM
I was wondering if anyone has used a corrected distributor cap with a high voltage setup? I have an Accel HEI Corrected cap mounted on my 350 and I just purchased a 6al MSD box. It ran great for about a day and now it runs like I am getting alot of cross igniting. I removed the cap and I see there is a wire visible above the epoxy resin on the inside of the cap. I am wondering if maybe the cap was only designed for a low voltage setup? Has anyone encountered a similar problem? Any help would be greatly appreciated. I really liked the difference the 6al made and I don't want to take it back. Maybe I should just switch back to the normal cap.
Thanks,
Justin
1971BB427 Jun 26, 2011 10:45 PM
Thanks,
Justin
That's a pretty easy way to check it, if you still have the old cap. Just swap it back on and see if the problem goes away. I've heard some bad reports about these corrected caps, and for what little they do asthetically I wont use one.
92 RS in training Jun 26, 2011 11:18 PM
yea I never throw away good parts. Never know when you might need them. I will do that tomorrow.
77nomad Jun 27, 2011 12:15 AM
Whats the corrected cap? I have the deal that adapts the blaster coil to a HEI cap. Is that it? If so I've never had trouble.
mr.blue Jun 27, 2011 02:02 AM
the corrected cap basically puts cylinders 1,3,5,7 on one half of the cap, and 2,4,6,8 on the other half so you dont have all the wires crossing. i was thinking about getting one after i saw the commercial but not now.
77nomad Jun 27, 2011 02:32 AM
Ahh a crab cap.
1971BB427 Jun 27, 2011 08:47 AM
Yeah, it's really something a high end show car owner would worry about, but they don't drive their cars much.
92 RS in training Jun 27, 2011 08:01 PM
Just wanted to let you guys know that the cap was not at fault for my car running like crap. I had to change my distributor today. It was all worn from the vacuum advance springs to the worn gear on the bottom of the distributor. There was about 1/4 inch up and down play on my rotor button which was digging into the underside of the cap. Exchanged cap and bought an Accel Hei distributor. Runs awsome now and I just wanted to clear things up so I didn't mislead or discourage anyone. Thanks for all the advice.
1971BB427 Jun 27, 2011 09:46 PM
Great! Glad you found the problem. Too bad it wasn't a cheap fix like a cap.
92 RS in training Jul 15, 2011 11:31 AM
Okay well it turns out you were right. I will never use one of those corrected distributor caps again! After the third one that faulted instantly I went back to the original cap. I can't believe I was so stupid to keep wasting time with that stupid thing! But hey, it looked real pretty sitting in the driveway.
