getting on the road
Old 10-04-2010, 09:59 AM
james hellsing's Avatar
lol yeah a job that pays for gas to and from work would be nice
  #72
Old 10-04-2010, 10:19 AM
i'll get that backdrive linkage out today for you
  #73
Old 10-04-2010, 02:03 PM
okay i need some help i've been trying to put my distributor back on the car and i can't get the thing on on the way theres about a 1/4 inch gap between the intake hole and gasket and the flange on the distributor saft thats supposed to rest on the gasket any ideas? i can't figure it out its annoying the heck outta me i'll post a pic so ya'll can see what i mean
  #74
Old 10-04-2010, 02:14 PM
  #75
Old 10-04-2010, 09:28 PM
Alright I got the distributor in, I rotated the rotor around till it went in all the way idk if it's in the right spot timming wise now. I thought where I had it was where the marks lined up but now its in at least. And I got everything hooked up except for the distributor vacuum line I can't figure out how to tell if it needs full or part vacuum. any help? I'm sure this is yet another noob question but I can't find anything on it in my manual.
  #76
Old 10-04-2010, 09:39 PM
It's a hei distributor by the way, I believe its the original 79 one.
  #77
Old 10-04-2010, 09:58 PM
80ZJoe's Avatar
July 2010 ROTM
Hey James, your prob with the dist. going in was most likely the oil pump not lining up with the dist., for that you would just take a flat screw driver to move it a bit (oil pump). Now once you have the dist. in the dist. should be pointing towards your #1 plug and your #1 piston should be a top dead centre.
  #78
Old 10-04-2010, 10:07 PM
80ZJoe's Avatar
July 2010 ROTM
This should explain better than i can lol.
http://www.youtube.com/watch?v=YdIGZ...1&feature=fvwp
  #79
Old 10-04-2010, 11:22 PM
thanks for that vid it makes sense. I got it in but im gonna have to time the engine cause I didn't mark where the rotor was originally so I'll have to figure out #1 tdc, the rotor is pointed that way but idk where its last position after running was anymore so yeah more fun before i get to try the new toys lol
  #80
Old 10-05-2010, 10:10 AM
yup, just start by setting it a tdc on the intake stroke. Then get the dizzy pointed toward 1 and the oil pump drive shaft lined up.
Quick Reply: getting on the road
