Gen light
Sometimes, depending on the voltage regulator, the engine initially needs to rev up (past 2k rpm's or so) to activate it. As long as the system charges fine once the engine is running, I wouldn't worry about it.
National Parts Depot has the dash carpets. Seats depend on what you want. Are you looking for something stock, or just something that looks good and is comfortable? If it's the latter, then you could find later buckets that are matching color and install them. A lot of GM seats interchange on the same foot print and bolt pattern.
evilbeef54
07-27-2008 09:47 PM
