Engine dilema
Old Nov 11, 2023 | 02:04 PM
Mike D's Avatar
Default Engine dilema
I bought my 72 Camaro, only to find out it has a 305 not a 350. No I didn't verify it before. My bad.
The VIN calls for a 350.
is it worth the cost to try and locate a rebuildable 350 in Tucson and sell the 305, or try to sell the car and move on ?
Thanks
Mike
Old Nov 11, 2023 | 02:44 PM
Well since you don't have the numbers matching motor unless you want an all original car I'd just buy a crate engine 350 if it's within your budget.
https://www.jegs.com/i/ATK-Engines/0...RoCHOIQAvD_BwE
You can try to sell the 305 but don't expect to get more than a couple hundred for it,someone will need it for something I'm sure but they're not exactly in much demand.
There should be plenty of used small blocks out there for sale the 350 being the most common far and away,check around as there might be one you can hear running that's still in a car or truck someone is parting out or maybe swapping in a big block or LS etc.
Keep in mind if you get a 400 you'll need a 400 flywheel or flexplate as they're externally balanced,otherwise a great choice.
86CAMARO350
82-92 V8 Tech
Sep 7, 2008 02:55 PM
hughesis21
Feb 11, 2008 06:13 AM
patrick2269
Feb 2, 2008 07:14 PM
Camaro_Kid
Jan 22, 2007 03:29 PM
92camaro305
Jan 3, 2006 04:52 PM
