Car falls on its face
#21
I had a Q-Jet on my 305....Like yours mine was fine for normal drivin but when I floored it after a while the engine would choke out. And I would have to let off for a little and then slowly get back on it. Eventually my top speed was reduced because I couldnt take it any higher (and that was when I was driving normally) My solution was to get a new Carb and Intake. Now I dont know if thats the solution for you but it sounded like both Camaros were doing the same thing...
#22
There are many reasons this could happen. The vacuum would be first look on the card are there any open slots where a hose would go? Also did you check the timing that is another factor? Tells us more about the setup all I got was truck motor and carb. Did you have this issue before the carb was rebuilt? What is the CFM of the carb?
