cant get shift knob off...pls help
i just got a shift plate for my 81 camaro but im not sure how to get the shift **** off to put it on..can somebody please give me some step by step instructions?
almost all of them should just unscrew, u may have to crank it some. If it wont come then there may be 1 or 2 screws on the front of it (side not facing you) that are holding it on.
ok i got it off but im not sure how to put that metal clip/pin that came off back on? i think it holds the button on so it doesn't go flying off when you let go of it.
Isn't there a slot in the base of the ****? Not 100% sure since mine came with a B&M megashifter. If I remember correctly there's a little slot in the base of the **** that when you slide the **** over the shaft you should be able to slide the clip in that slot and snap it in.
ok i think i see a slot but when i put it in there, the button doesn't wanna go down..and the screw must be old cuz i think the top is wearing down as im screwing it..
