Body Panel help
2 Attachment(s)
Hey guys,
I picked up an 81 Camaro a couple weeks ago, just been going through it and getting it running good. Now on to the ugly issues... Is there anywhere that sells a patch panel for the metal in FRONT of the rear tire? I haven't seen one, but as you can see I need one (and a rocker, and a door skin lol) Thanks a lot for the help. If not I guess I will be searching through some junk yards. |
it looks like theres a lot of bondo there i would scrape off as much as you can before ordering so you can get the right panel might need a quarter but hopefully just the patch!
I do not think the body work that was exposed was done by a pro. Like Greencamaro said strip everything before ordering. 3/4 quarters (or quarter skin) are cheap and a lot easier then 2 or 3 patched.
Nothing wrong with bondo but it should never be thicker the .060-.070" (1/16"). You sure don't want to spend money on a paint job unless you sure of what you are putting is on. https://www.autobodyspecialt.com/cgi...on&key=CA-7-LH |
| All times are GMT -5. The time now is 08:49 AM. |
