Biggest Tires on a camaro!
Old 12-30-2008, 03:11 PM
80Z2815's Avatar
Default Biggest Tires on a camaro!
I need Help!
I have a 1980 Camaro that i want to put ET Streets on the back but i don't know what size.
I have been told that i can fit 12.5x28-15 on a 10in. rim on the back without it rubbing at all and i was wondering if this is true? or will i have to put Air Shocks and Drag Bags in it to keep it from rubbing.
If You have any suggestions on tire size please tell. I am going for an Aggressive Street/Strip Look!
Old 12-30-2008, 03:57 PM
randy129's Avatar
Default RE: Biggest Tires on a camaro!
Here's a chart that will provide some guidance. I'd be surprised if you get anything wider than 10" tucked without rubbing, and I believe you would need to roll the inner fender lip at that.
Old 12-30-2008, 04:45 PM
80Z2815's Avatar
Thank You man this helps a bunch!
this just goes to show the guy that told me i can fit a 12in. wide tire in the back without mods is a liar!!
Old 12-30-2008, 05:24 PM
zman3689's Avatar
The biggest tire/wheel combo we could fit on my '80 Z28 was a 275/60/15 tire on a 15x8 inch wheel with zero backspacing. I don't think there is really any more room for anything bigger without relocating some things.
Old 12-30-2008, 06:00 PM
randy129's Avatar
I have a buddy who ran 12" width on a '77 with no body mods (back in the day), but it was jacked up high with air shocks. :-O
DISCLAIMER: This was on my '69. :-) I ran 17x8's on the front with 4.75 offset and 17x9.5's on the rear with 5.5 offset. I might could've got a 10" wheel in there, but it would have been real tight. There's a guy on this site (Red70Camaro) that I believe is running that same combination on his '72.
I'm actively lookin to replace it with a 70-72 RS.
Spend some time searching the archives and I bet you'll find someone with an '80 model that lists their diameter, width and offset.
Old 12-30-2008, 06:17 PM
Men around these parts laugh at your girly list.
Old 12-31-2008, 10:36 AM
randy129's Avatar
I'll see your lime third gen and raise you a lemon first gen...
Old 12-31-2008, 11:16 AM
1979RS's Avatar
roflmao~!
Old 12-31-2008, 03:15 PM
Thoreau's Avatar
Sorry to get off topic but that is one sweet ride, randy. I also like the way you took the picture. The tire combo is sweet....
Old 12-31-2008, 04:13 PM
randy129's Avatar
Thanks, it was a fun ride. I'm hoping to find a good 70-72 to replace it.
The pic (above)was taken behind a buddy's house. The other five below are his and his pop's.
Quick Reply: Biggest Tires on a camaro!
