BANG
Old Jun 17, 2008 | 06:29 PM
thebandit110's Avatar
Default BANG
i just put a holley dominator on my car. and i got it running. but every so often it makes a big BANG noise. out of the tail pipe. ive tried advancing the timing thinking it could be advanced but to no sucess. and ive also tried to lean it out or rich it out to get it. what am i missing. but when it does it, you can feel a puff of air out of the tail pipe. and its super loud. any ideas?
Old Jun 17, 2008 | 08:16 PM
GRIFF's Avatar
Default RE: BANG
Did it do it before you changed the carb? is the carb all you changed? When does it do it and how big of a carb is it?
Old Jun 17, 2008 | 09:17 PM
Default RE: BANG
nah, the noise was not there before i changed the carb..after changing the carb i put some nice new ac delco plugs in it. the carb is a 1050 holley dominator. ( just an over sized regular holley). . the noise is very irratic. happens once every so often. i checked out my ignition and it seems fine. took the cap off made sure all wire connections were good. very confused. could it be to lean and thats why it makes a bang noise? any ideas?
Old Jun 17, 2008 | 09:35 PM
GRIFF's Avatar
Default RE: BANG
I cant see your engine pic real well what are you running, is it modified?
Old Jun 17, 2008 | 09:47 PM
Default RE: BANG
yeah, its a 396 its got 11:1 domed pistons. big cam. (forget what size). roller rockers, electric fans. electric pump. all kinds of fun stuff i cant really remeber all of it at the moment.
Old Jun 18, 2008 | 09:55 AM
NorCal_71's Avatar
Default RE: BANG
It sounds to me like you are getting a crossfire, double check all your spark plug wires and make sure none of them are touching each other or arcing on the engine.
Old Jun 18, 2008 | 09:08 PM
Default RE: BANG
so im having a brain storming session while at work. and i remeber when i changed the plugs i got 2 of the wires criss crossed. and i double checkd the firing order. and sure enough i f'd it up. got it running. didnt really adjust it thought. since its 10 and my neighbors are da gay about the car. so it was running way rich. but ill take care of it tomorrow. thanks for the help guys.
i feel so stupid.....
iCrossbone
LS Series Tech
28
Jun 8, 2011 01:05 PM
Bankos66
Nov 5, 2010 03:20 PM
CamaroZzz
82-92 V8 Tech
Oct 24, 2009 08:33 PM
DIPSTICK_JIMMY
Sep 8, 2009 10:41 PM
ChrSStne
Dec 27, 2008 01:19 PM
