Backfiring
Old Oct 15, 2010 | 04:22 PM
1977Camaro350's Avatar
Default Backfiring
I used to have a Quadrajet on my Camaro and it always backfired and popped when I used the engine to slow the car.
Then I put an Edelbrock on it and the backfiring was gone. But now its started to do it again. I just figured something on the carb needed to be tweaked a bit, so I fiddled around with the two mixture screws and it didn't seem to change anything. I really don't know what I'm doing when it comes to adjusting carbs but if anyone has suggestions of what to do that would be great.
Old Oct 15, 2010 | 06:22 PM
Sometimes it's not the carb, but the timing. A new carb might make it go away because it runs richer and wont backfire as easily. Try putting a timing light on it and check the timing.
Old Oct 15, 2010 | 11:28 PM
That's called "rapping", and if you have a free flowing exhaust, it's not all that uncommon. There is normally a small amount of unburned fuel in the exhaust (engines aren't 100% fuel efficient), and what you are hearing is the gas burning in the pipes. With a conventional, more restrictive muffler, you wouldn't hear it. Exhaust systems with catalytic converters burns the gas off inside the cat (that's part of it's job).
Old Oct 16, 2010 | 07:39 PM
I reset the timing and it the rapping isn't as bad now, and the car runs quite a bit better. Thanks for the help.
SilverBlueLS1
LS Series Tech
16
Jan 23, 2012 12:58 PM
BrianFol
Dec 30, 2011 02:27 PM
uriss
70-81 V8 Tech
Aug 22, 2011 12:04 AM
interex1982
Feb 6, 2007 08:19 PM
jfk1970
Aug 11, 2005 10:08 PM
