Auto to manual
I have a 70 Camaro that was a factory automatic. Right now im putting in a Muncie m20. I was looking to install the bracket that mounts to the frame to support the z bar, but the three holes on the frame didn't match the pattern on the bracket. Do I have to drill those holes myself or am I just missing something.
It's called the frame side pivot ball bracket Thanks |
1 Attachment(s)
You sure you got the right bracket? This is what your bracket and corresponding frame hole positions should look like:
Attachment 20515 |
Oh I musta been looking in the wrong spot. Just to be clear is that the outside of the drivers side rail?
That is exactly where mine is. I also did the swap. The holes get tapped by the bolts.
Well when I bought all the stuff for my swap I failed to remember the new brake pedal. I was thinking about just cutting up the original to the size of the manual pedal. Any objections??
| All times are GMT -5. The time now is 08:34 AM. |
