Aluminum Heads
Old 12-27-2012, 11:56 PM
79 midlife crisis's Avatar
Default Aluminum Heads
Hey guys, new to the camaro world and am in the process of building a 79 camaro for the street and track and am looking to put aluminum heads on the 350 and found aluminum heads from a 99. Will they fit?
Thanks in advance for your input!
Old 12-28-2012, 05:39 AM
No and yes. If its a LS motor no. If its a Lt1 they will physically bolt on but are reverse rotation cooling heads and you will need a water pump that flows reverse. Not much power to be had either. Leave em alone.
Old 12-28-2012, 08:48 AM
Thanks for the insight Nomad!
Old 12-28-2012, 09:41 AM
Edwardgp's Avatar
Welcome aboard 79.
Old 12-28-2012, 09:52 AM
The LT1 ended after the 1997 production year, so you must be looking at LS1 heads if they are from a 99.
You can make LT1 heads work, but LS1 heads are a different configuration and won't bolt up to the block at all.
Old 12-28-2012, 10:36 AM
Thanks guys, big help! I just picked up this car, overall it's complete less motor and tranny. I've got the camaro bug now and can't wait to get this on the road. I just pulled the motor and tranny out of my demolition derby truck to freshen up and put in the camaro. I do have one additional question........the truck is an 84 3/4 ton with a TH400 long. Will the trans mount match up to the cross member? I like the idea of having this beefy trans in the car for future HP upgrades.
I'll post pics soon..........Thanks again!
Old 12-28-2012, 10:51 AM
Edwardgp's Avatar
You will need the 6" tail shaft for that transmission.
Old 12-28-2012, 11:23 AM
Your car came with the short tail (6") TH350, options were a 6", 9" or 12" tail. Overall length is 27-5/8" with the 6" tail.
The TH400 with a 4" tail housing is 29" long overall (1-3/8" longer). Tail options were 4", 9", or 13".
You'll need the correct driveshaft, having a minimum of 1/2" pullout clearance.
Cross member mounting pad on the 350 is 22.25" back from the bellhousing, the 400 is 27-15/16".
Old 12-29-2012, 09:56 AM
Edwardgp's Avatar
They have a cross member for that conversion at PATC I believe. Could be wrong it has happened before 79.
Old 12-29-2012, 11:04 AM
YAV8's Avatar
Save the money on the conversion and have a good shop build the th350. It takes less power to run then the 400. Put the 400 up for sale and its gone to a good home for someone making gobs of power. I have one question on the LT1 heads that someone mentioned. I think you can bolt them on but the head gasketss are all wrong. I had two people try to use Lt1 head gaskets on a gen1 block and it didn't work. Also not sure where you would find a water pump the pull water backwards with the Gen 1 blocks. The best I have seen the the LT1 heads is to sell them for scrap unless your work with a LT1 block.
Quick Reply: Aluminum Heads
