74 Rear end
depends if the ring gear was the same ratio
i had a 3.42 open diff that i put a stock posi from a 2.92 gearing and it is shimmed all the way to one side almost and i had to cut the drum on one side for it not to rub on the back plate.
so i don;t suggest that, but when i was 18 i made it work
If you buy gears from Richmond you can put whatever gearing you want in it and not shim. Richmond makes them for various size 10 bolts to work without the shimming.
Page 220 of Summit Racing's catalog.
libertyforall1776
11-10-2007 03:04 PM
