70 camaro 3 piece door panels
Old Jul 9, 2011 | 11:30 AM
Texas70z28's Avatar
Default 70 camaro 3 piece door panels
does anyone have a pic of what fasteners are used to fasten the top portion of 3 piece door panel for 70 camaro. There are like 4 square indentions with a hole in the center of each. It looks like there are a few more holes that the center door panel piece clips just push in, any help?
Old Jul 9, 2011 | 05:37 PM
Don't have a picture, but I can describe them. They were phillips head screws with a large flat washer head that was around 1/2" diameter head and about a #8 screw 1/2" long. Any similar washer head screw from a hardware store will work fine as long as it's not too thick a head.
Old Jul 13, 2011 | 11:33 PM
Texas70z28's Avatar
did they screw directly into door or did they have those metal clips that are threaded? when i got the car doors were stripped except for window regulators and door latches, so i have nothing to go off. Do u know if those fisherbody books are any good? i bought the factory manuals and they were not very helpful for interior stuff,thanks
Old Jul 14, 2011 | 09:06 AM
They screw directly into the door metal on mine. There is a slot in my top panel, so it can line up with the hole they go into.
Old Jul 18, 2011 | 11:28 PM
Texas70z28's Avatar
so do u think those kick panel screws with a washer on them would be too thick? they need to be completely flat?
Old Jul 19, 2011 | 09:13 AM
No they'd probably work, but the length may be a concern if they're longer than 1".
Old Jul 21, 2011 | 08:12 PM
Texas70z28's Avatar
I was thinkin i saw screws like that holdn my roof drip rails on i bet their the same? Last question the clips that hold the vinyl panel on do they just go into door? I saw a kit that shows little rubber fittings that go into door and it appears the clips push into those?? One site said 67-69 camaro and other said 67-74?? Any help so i know what to order, thanks
Old Jul 21, 2011 | 11:56 PM
There are plastic inserts that go into the doors, then the panel clips snap into those.
Old Jul 22, 2011 | 12:01 AM
The screw you really want to attach the upper panels is a "phillips modified truss head" that's used to screw metal studs together on sheetrock walls for commercial construction. Here's a picture of them on the bottom left side of this page:
http://www.grip-rite.com/files/Grip-...rochurered.pdf
Most hardware stores carry these in stock, or Home Deepot, Lowes, etc.
Chaotic94
Oct 3, 2011 02:43 PM
WIspartan1026
Apr 12, 2010 03:53 PM
lilman316
Oct 2, 2009 07:06 PM
