69ss
RE: 69ss
If you look at the trim tag and their is a x code that can possible tell you if you have an ss. But if you have an x11 coded car then it could be an ss350 or a base car with style trim. Or if you just don't have an x code like my 69' you can tell by looking at things like if it has a 12-bolt rearend with multileaf, and if its a big block car there would be a 3/8 fuel line instead of the standard 5/16. But after 37 years their is a good chance the rear could have been pulled and almost always the motor and trans. Check out this website it should help you decode you trim tag. http://www.chevy-camaro.com/chevy-ca...-tag-dehttp:// This second website is just if you want to decode your rearend just for kicks. http://www.camaros.net/years/69/69rearcodes.html
