383 vortec carb CFM?
383 cid
about 10:1
500 lift full roller 245@.050
vortec heads (2.00int, 1.55ext)
super victor single plane.
this combination on my desktop dyno yeilds about 480lbft at 5k and 510hp at 6k
the carb calculators i have been searching on say a 670cfm will work for me.
anyone else running a similar setup? seems a little small for my setup. was originally looking for a 750dp
about 10:1
Tell us more about your car. What gears, tranny, intended use? The cam and intake say drag race. If thats it then a good ol' 750 DP. I have a Proform on my stroker. Couldn't beat the price at the time. Now there are a couple others in the same price range. I wanna say mine was about 500-550. I really can't remember.
If your building a fast street car with an automatic trans. A 750 vac secondary would be a better choice.
Would you be interested in plugging my combo into DD. I don't think its really close but just for fun I'd like to see what it says. I have head flow data and camshaft timing to input. Please! Oh yeah welcome.
383 cid
about 10:1
about 10:1
DD is a nice aid to guestimating HP, but from what I've seen it's almost always quite high. I've had a couple friends who ran DD on their engines, and then dyno tested them, and in both cases the engines were around 40-50 hp less than DD came up with.
As Camaro 69 said, there are variables that DD doesn't take into consideration.
sure, gimme some specs. i love playing with this thing,
and although it may not be HP accurate, it should be fairly accurate at which combo's make more power than others.
here's what i got plugged in for mine,
looks like its closer to 500hp. i think its about 506 if i remember right
I agree, I only use DD out of curiosity, to see what type of changes different components will make. Take the numbers with a grain of salt.
One thing I missed, you're running a roller cam, mine is flat tappet.
And, are you using large tube (1-3/4") headers? Change those DD specs if you're not.
i don't have the headers yet. but the header calculator i used called for 1 3/4 x 37.5 primary tubes.
so i'll look for some 1 3/4 by 30's maybe, summit has a lot of those available.
or maybe screw the length, schoenfeld has a lot of good 1 3/4 headers available for fairly cheap.
oh yeah...
i'm running 4/10's
auto trans, with shift kit and 2k stall speed
oh yeah...
i'm running 4/10's
Did you, out of curiosity, run the numbers on smaller primary headers? Those may give you a lower rpm torque curve (you're peaking past 6 grand now), which is more street friendly. Not to mention the possibility of having less clearance issues. I put these headers on my car, and it appears to like them. Sounds like a good concept, but I didn't have the means to do an "old to new" field test. Flowtech 49100-1FLT - Flowtech Afterburner Headers - Overview - SummitRacing.com
Most of my experience with carbs comes from a few years back, but one thing I learned was a lot of motors are over carburated. I have always run AFB's so my choice of carbs now will be Edelbrock. I think you are close with the 670 you came up with.I'm looking at building a mild 350 and am going to run a 500cfm.
