so what is your guesstamit
So i finally am starting to wonder what ive got as far as HP i have a 350 bored .30 over. then for the mods i have comp cams high energy cam 268 duration, .454 lift. w/ hydraulic lifters. a holley contender intake, a holley 650 cfm carb. an electric fan and a Be Cool aluminum radiator. i also have a set of 1.5 roller rockers but they arent on the car yet. so what do u guys think i can be lookin at as far a HP and Torque. also what would you guys recommend for some more HP!!!
RE: so what is your guesstamit
you sure your rockers aren't 1:6? what are your heads, pistons (dome or flat top) exhaust, etc? that is a pretty big cam for a mild motor. what kind of gears and converter are you running behind it?
