1978 Z28 Brake Light and Turn Signal Issue
Hey everyone, looking for a little help here. I've got something odd going on with the car. I recently lost my turn signals and hazard lights. I checked and even changed the fuses. The fuses weren't bad to begin with but i figured it couldnt hurt to throw in a fresh fuse. That didn't solve the issue. I then changed the flasher and the hazards briefly flashed and then stop working again. The turn signal switch feels perfect in the column when I push it up or down. The car only has 13,000 miles on it so I don't think wear would be an issue. Anyways, this morning, I lost my brake lights which had been working the whole time even after I lost turn signals and the hazards. I checked the fuse and again it was perfect as it was a new fuse because it is on the same fuse as the hazards and I had replaced it. My taillights and headlights along with the high and low beams work perfect. As does everything else coming from the fuse panel. Any ideas or suggestions would be much appreciated!
