What is a good paint gun to spray Heavy metallic base coat?
Old Feb 15, 2015 | 10:19 PM
Camaro1931's Avatar
Default What is a good paint gun to spray Heavy metallic base coat?
I plan on painting my classic. It is premiered though I have to fix a few corners... Should I grind down the edges and do a 2k primer? Also another know where can I can a good dvd to watch for this. I want to do a good job as this is my first. Please Advise
Old Feb 16, 2015 | 09:51 AM
Icecobra's Avatar
I would check at your local college and see if it has a body and fender class. That's the cheapest training I have found and you get to practice. Your not going to learn what you need to know from a DVD or watching it on you tube. Painting a car right requires skill and a painter that knows what he is doing. Keep in mind shooting the paint on the car is less than 25% of the job. All the real cost and expertise is in the prep work. Most body guys will tell you they are professional sanders not painters...
Old Feb 17, 2015 | 06:01 PM
Camaro1931's Avatar
Okay that did not help.
Old Feb 17, 2015 | 08:00 PM
Icecobra's Avatar
What would help?
Man In Black
May 13, 2015 07:48 AM
Glen e
Dec 4, 2014 09:23 PM
HEAVYCHEVYMAYNE.
Jan 4, 2008 06:43 PM
frostlime69
Nov 30, 2007 02:41 PM
