69 Brake Auto-Engagement Issues
Hello all,
I am aware that there are numerous postings/threads about brake issues however I have not come across one that describes the situation that is occurring with my 69. Short Description: After driving for approximately 6 miles with normal braking situations, both front brake calipers will not release i.e. lock up, drag, and will not release until the car is parked and off for ~30 min. Relevant Vehicle Components:
Investigations performed:
What do you all think? Have you experienced anything like this? 1969 Camaro | COPO Clone | V8 350 SBC 5.7L LT-1 | Quick Fuel Holley 4 Barrel DFT Slayer | Doug's D368 Headers | MSD Ignition Street Fire HEI Distributor | Disc Front | Drum Rear |
You might disconnect the rod from booster-to-pedal and shorten it by about min2 turns and try again.
If better, but not perfect, add another thread to adjustment. |
Was something changed on the brake system? If not this is almost always the hose going bad at the front calipers. The hose degrade on the inside but since there is thousands of pounds of pressure when braking that will push through the collapsing hose. But you need to release the pressure the hose will only let the pressure bleed off so fast as the pressure drop it bleeds off slower and slower. I have had customers tell me they waited 10 hours only to have it bind up again after they used them.
I would suspect any hose more then 8 years old but I have seen them fail at 5. Any brake job you do and they are more then 7 years old should include new hoses. I do not mean to say all hoses fail. A few years ago I did my 67 and I think the rear hose to the rear end was original to the car. Just that 80% of the time that a car showed up with sticking brake it was cause of a hose and 18% or so it was rust in the brakes system. The rest where old ball stuff like a stuck slider or contaminated brake fluid, a damaged seal that was binding. I have never had to adjust anything at the master unless there was new aftermarket parts involved and you where messing with the design of the brakes. |
| All times are GMT -5. The time now is 04:39 AM. |
