Window Weather Stripping
This is probably a silly question. I want to make certain that I order all of the right parts. I need the trim piece that fits between the front and rear windows. Right now there is nothing there - no steel/chrome piece, no weather stripping on either window.
I'm thinking that I need https://www.classicindustries.com/ca...arts/k355.html and also https://www.classicindustries.com/ca...rts/k1048.html. I can't tell from the item descriptions if there's a third piece that I will also need. Thanks in advance! Robert |
You will also need these. This is the chrome trim and rubber inserts you have pictured above. I just ordered this from here.
http://www.camarocentral.com/product_p/bcm-84.htm |
Classic and most places sell kits with the rubber mold inset and the chrome molding(cheaper). Also the rubber seal that slides into the molding isn't easy to get in. I used some whit litheum grease. Do yourself a favor though, Buy a stainless steel set not chrome unless you want to deal with rust. Just speaking from my experience. Good luck and enjoy!!
