NOS not working
Just tried my NOS today and it doesnt seem like its working. Its a 10lb bottle and i weighed it at about 20lbs (should be 24lbs when full) so it shopuld have plenty in it. The carb switch seems to be working as is the button on the shifter. But when i hit the button at full throttle nothing happens. There should be a noticlible feel shouldnt there? What else could my problem be? What is the best way to test the system?
Any help would be appriciated |
RE: NOS not working
unhook the lines from the carb and hit the buttonif it aint spraying your wiring is bad...if you hit the test botton with everything hooked up,you have to be in the rpms or you will boom your motor,hold the rpms up and tap the button,it should rev up or bog down,if it revs up,all is well if it bogs down your only getting fuel,and yes it should make a difference,right now im actually wiring mine up....you must have it wired wrong,the sylinoids should click...
RE: NOS not working
The solinoids do click, at least i think they do, i put my finger on them and can feel them click. I know i am getting fuel, maybe i will crack the NOS line to make sure the NOS is getting up to the solinoid.
