Front left fog light. 69 z28
Old 09-16-2008 | 07:40 PM
scott14oh's Avatar
Default Front left fog light. 69 z28
Hello, I have an original 1969 z28 camaro and am having a problem with the left front fog light. The left fog light does not turn on unless it is blinking as the turn signal. The Right fog light is working. I have even tried switching bulbs and it doesnt change anything.
This is strange to me, because, if it was a problem with the switch, why would the right fog still work? Also, why would it only work when the blinker is engaged?
Thanks for any suggestions.
I have tried jiggling the wires, but it does change anything.
~~~edit~~~
I didn't know i could post this on the main page. Sorry for the double post
Old 09-16-2008 | 08:08 PM
Default RE: Front left fog light. 69 z28
Well, for starters, those ARE NOT fog lights. They are running/turn signal lights, and they have double filament bulbs. One filament goes on with the headlights, and the other is the turn signal. Since you seemed to have ruled out the bulb, your problem is either a bad socket (broken/corroded), a broken feed wire, or even a bad ground. My money's on a bad wire or socket. You need to dig more.
Old 09-16-2008 | 08:19 PM
scott14oh's Avatar
Thanks for the reply. Right, the bulb is not the problem, because it works in the other side. If its a bad socket, wouldn't the turn signal not work either?
Old 09-16-2008 | 08:50 PM
scott14oh's Avatar
We just found the problem. The problem is the connector that the wires lead to.
Barry J
05-10-2015 09:59 AM
atikovi
03-27-2012 08:33 PM
kpmunt
06-11-2010 07:33 PM
Cowboy Joe
02-04-2007 05:15 AM
