Big Block Oil Pressure Line Bracket
I am installing the OEM type oil line which has a copper tube from the block port to a bulkhead adapter that mounts to a small bracket with a single screw. Then it changes to a plastic flex line through the firewall and into the gage in the console. Where does the bracket mount?
Thanks in advance! |
Nobody has a factory big block 1969 Camaro?
1 Attachment(s)
Here's the page from the assembly manual that shows it:
Attachment 8537 |
