8.1 vortec 496
Old Dec 24, 2007 | 03:59 PM
camaro's Avatar
Default 8.1 vortec 496
I got a question,and I hope someone can help me,I bought a 8.1 vortec 496 2001 ,I think, It's from a truck,I think ,anyways I would like to put it in my 69 camaro,can this be done and can I install all the "goodies" any chevy big block has" HELP!" by the way I paid $1000.00 was that to much?
Old Dec 24, 2007 | 05:01 PM
GMDCAMARO's Avatar
Default RE: 8.1 vortec 496
I dont know, but that would be a badass camaro if you can!
Old Dec 26, 2007 | 12:24 AM
butler68's Avatar
Think positive, anything can be done!
Old Dec 26, 2007 | 09:58 PM
FlightMechYJ68's Avatar
The main problem that you are gonna have with that swap is the oil pan being WAY to deep and the intakeWAY to high. It can be done. $1000 is a pretty good price if it runs and doesn't have any error codes on it. I'm not sure if you have done any research on this swap, but if you haven't you need to know that you will have to have the coputer plashed and reprogrammed to let the motor run in a different vehicle. If you got the transmission with the motor then that is even better/easier. I had John at www.speartech.com do my engine harness/computer flash and it was the best $750 I had ever spent. Ever. I don't know if he works with the 8.1 or not but I am sure he could figure it out.
Old Jan 19, 2008 | 11:25 PM
DesertEagle's Avatar
I've seen that engine in 2500s dualies. I did something similar, taking a 7.4L 454 out of a 3/4ton C20 Sub. I had to buy a Milodon oil pan and milodon oil pick up. Also I first looked at the standardbig block engine mounts for a 69 camaro. The ones i found at autozone, checker, and napa were all made somewhere in thailand or something, so of course they didn't fit. To make it work out i had to shave 1/4 inch off othe center of the mounts which connect to the subframe (sorry not sure what to call them, but they are not engine mounts.) then weld them back together.Good luck with the computer on that 8.1
Desert Eagle
brownstone101
Mar 3, 2010 08:27 PM
Intrepid781
82-92 V8 Tech
Apr 1, 2009 03:31 PM
Redneck97
Nov 29, 2006 01:23 AM
89camaro
Nov 6, 2006 03:18 AM
