67 Camaro - Clutch Pedal
Mine did something similar, ended up replacing the clutch and pressure plate. Some of the springs on the pressure plate had given up. Maybe just the throw-out bearing slipped out or the push rod that actually pushes the fork slipped out. Just guessing at some stuff.
1967, 67, adjust, adjustment, camaro, clutch, forum, install, installing, linkage, lost, pedal, pedals, pressur, recommended
