383 stroker problems...
Old 04-21-2012 | 10:12 PM
Spaghettios's Avatar
Default 383 stroker problems...
I have a newley built stroker that I have a pretty bad vibration going on, I have the weighted harmonic balancer and the weight plate that goes between the crank and flexplate so it should be balance alright but I have installed a saginaw 4 speed and now there is vibration, I havent even had the chance to put it into gear cuz of the vibration.. I have also noticed there is weights on my crank pulley... is that normal or could that mess it up? The car sounds fine when at idle but if I give it even a little gas all hell breaks loose and it rattles and shakes pretty bad, enough to tell me not to run it anymore. It is bugging me and I dont know what else to do, Is there things im missing? doesnt sound like a misfire... motor mounts? please help!
Old 06-08-2012 | 05:48 AM
Indiancreek's Avatar
Is your bell housing centered with your crank? You can get offset dowel pins to center the bell housing. Use a dial indicator to see if it's off or not. Since the vibration comes into play when the trans is installed.
Old 06-08-2012 | 10:13 AM
is the trans the same one that was in it before? are all the parts new or original? if the balance is not correct it will vibrate more as rpms are increased. a bent trans shaft or misaligned flywheel may be the issue. can you see the flywheel when running. if so look to see if its wobbling or could use a mic an turn the crank and measure to see if its wobbling
Old 06-08-2012 | 12:53 PM
StoveBolts's Avatar
I was curious if you had your flywheel balanced too.
Old 08-30-2012 | 03:44 PM
Smee78's Avatar
I guess we will never know what the problem was.
Old 08-31-2012 | 12:09 AM
AboveTheLogic's Avatar
...another one of life's great mysteries...
Old 08-31-2012 | 06:49 AM
YAV8's Avatar
Did you put in a pilot bearing when you when to the 4 speed. Also with a new 400 style crank their need to be a dowl pin installed to correctly bolt on the flex plate or flywheel. This pin is centered between two bolt holes and must be their.
jimcates3
10-05-2012 09:09 PM
thebious
10-06-2011 02:49 PM
maddog1415
08-21-2011 06:21 PM
NorthernCrew454
07-22-2011 05:45 PM
NoahTwoTeN
02-16-2009 02:11 PM
Quick Reply: 383 stroker problems...
