327 Won't Turn Over with Lights on
Old Dec 17, 2011 | 04:22 AM
Jimmyvegas's Avatar
Cool 327 Won't Turn Over with Lights on
I have a 1968 Camaro w/327. 1000 miles on rebuild. Runs great and purrs like a kitten. Having problems starting (won't turn over) however when lights/heater/brakelights/parking lights are on or any kind of power draw. When all power consuming features are off, turns over and starts just fine.
Recently tightened and cables from battery to the starter. But I'm thinking a bad cable? New battery installed a month ago.
Thoughts?
Thanks!
JV
Old Dec 17, 2011 | 07:58 AM
Check all your grounds, start with the ones under the hood. Make sure your negative battery cable connection to the engine block is good, and that you still have a ground strap jumping from the block to the body.
Old Jan 7, 2012 | 07:29 PM
Smee78's Avatar
"ground strap jumping from the block to the body" Hey 69, is this a mandatory item? I'm rebuilding my 68 after many years of disassembly and dont remember taking one off.
Old Jan 8, 2012 | 01:42 PM
swalsh's Avatar
Hi Smee78,
I just put my 68 back together (mine did not have a block to body strap either) and yes...you def need a strap from the block to the frame (mine is on the passenger side by the starter) and another from the block to the body. I bolted mine from a valve cover hold down bolt to a screw on the firewall. Got my brass strap kit at Harmons at www.harmons.com. Comes with instructions showing locations as well. nice kit!
Old Jan 21, 2012 | 07:59 AM
StoveBolts's Avatar
Originally Posted by swalsh
Hi Smee78,
NAPA has the straps too... and you don't have to pay shipping
jackrabbit_slim
Oct 2, 2009 11:14 PM
cautioncones
Jan 7, 2009 04:21 PM
dustinb
May 1, 2008 06:27 PM
JaySan
Apr 18, 2008 04:32 PM
