What kind of carrier is this?
Old 10-12-2018, 09:37 PM
gmshadow's Avatar
Default What kind of carrier is this?
Had to replace an axle on the 67 Camaro with a 10 bolt 8.5 Posi traction. Rear gear is a 4.10, but didn't really recognize the carrier. Has been awhile since have been into one, but that funny looking spacer between the side gears does not look familiar and not finding any pictures of it on the internet. Looks like would be a chore to remove it also . See picture attached
Old 10-13-2018, 07:21 AM
MKCoconuts's Avatar
It's for the limited slip (posi). Puts pressure on the the clutch pack
Old 10-13-2018, 03:34 PM
Everett#2390's Avatar
Carrier is not OE design for '67 as one, instead of spring shown, there should be two plates and four coil springs in pressing clutches together.
Also, plates under arrow would not be shown and diameter would 8.2 inches.
after cover is back on, use GM LS additive and do figure eight's
Old 10-13-2018, 03:57 PM
gmshadow's Avatar
I think the rear end is actually from a 1971 or later Nova. Why it was changed don't know, but as a SS/RS thought it should have had a 12 bolt and the single traction rod. Floor reinforcement and mounting studs are there, but bracket is not on rear end housing. Ring gear is 3988515 - 4.10 dated 86. and is an 8.5 rear end. Has mono leaf springs with traction bars welded to the spring plates and bolted to the spring on forward end. The plan is 2 inch lowering multi leaf springs, with 2 traction rods attached to the floor instead of the one. The carrier just looked odd to me and wondering if a Yukon or some other oddball.
Old 10-14-2018, 12:32 PM
If a 4K, 4L, 4N, or 4P on Trim Tag, lower left corner, then camaro was born an SS and would have a 12-bolt axle.
Old 10-14-2018, 01:21 PM
gmshadow's Avatar
It is a 4P , Los Angeles build. I think they were doing some drag racing with it. It had a fiberglass tilt front end on it when I got it, Corvette 350 and a T5 transmission.
Old 10-14-2018, 07:00 PM
MKCoconuts's Avatar
It's a Richmond carrier, if that's what you were asking.
Old 10-14-2018, 07:02 PM
gmshadow's Avatar
Thank You, that's what wanted to know
MikeJ67
24
07-24-2017 09:20 PM
mikes68
09-11-2013 05:50 AM
67SuperSport
07-04-2012 12:44 PM
ESPN8THEOCHO
70-81 V8 Tech
08-15-2008 10:09 PM
daltons 1980
04-17-2008 03:32 PM
Quick Reply: What kind of carrier is this?
