upper A Frame Mounting
Old 07-10-2018, 07:39 PM
gmshadow's Avatar
Default upper A Frame Mounting
Hi, getting ready to start assembling the Subframe for my 67 Camaro. Where the upper A Frame mounts I have 2 sets of holes.`' Someplace I found that lowering the mounting points was beneficial. In the past looks like the upper holes were the only ones used. So the question is which ones do I want to use and why.
3 See picture. In the process of removing a Tilt front end and replacing with original sheet metal . Turning into a bigger project than thought it would be.
Old 07-10-2018, 09:51 PM
From the factory, our cars only had the upper holes. A previous owner drilled those lower holes on yours, it's what's called the "Guldstrand Mod". You can read about the handling benefits here: How Four Holes and a Bit of Time Can Dramatically Improve Your Car?s Performance in the Turns
Old 07-10-2018, 09:58 PM
Al Loyrat's Avatar
Does the lower arms have 2 sets of holes?
Old 07-10-2018, 10:12 PM
gmshadow's Avatar
Thanks, looks like they set the camber to zero after modification, but they don't say what the caster is.
Looking at my holes not sure the lower ones were ever used. Can see the bolt knurl marks on upper holes, but no marks in lower holes unless used a non knurled bolt. Guess will try the lower holes and see what happens. The daughter may want to try an autocross or two.
Old 07-11-2018, 12:18 AM
gmshadow's Avatar
No, only one set of holes for lower control arm, 2 sets as pictured for upper .
Old 07-19-2018, 12:31 PM
Just1More's Avatar
Thumbs up
Great info
Old 08-01-2018, 06:14 AM
Smee78's Avatar
Interesting read, I have not heard of this method before, thanks for the article 69.
BrianR88
01-08-2020 11:09 AM
Socom
07-19-2011 03:32 AM
sparky555
08-18-2010 04:52 AM
abad67
10-12-2008 02:27 PM
couger111
11-14-2006 04:13 AM
Quick Reply: upper A Frame Mounting
