rear brake disabler
ive heard there is a kit u can buy that disables the rear brakes for burnouts at the flick of a switch. does anyone know if this is true, and where i can purchase the kit, thanks
RE: rear brake disabler
It's called a LINE LOCK KIT! Buy it from Summit or Jegs.
http://www.jegs.com/webapp/wcs/store...tegoryId=26861 |
B.T.W. Say good bye to your tires.
if your proportioning valve is working correctly you don't need it. waste of money. Sick
i didnt even think of using the proportioning valve, thats a smart idea, but id prefer to have a an on/off switch inside the car as opposed to having to get out into the engine bay and reset the valve everytime, but thank you both for the help, gratly apperciated
It's a good thing to have if you're drag racing. Proprtioning valves are good too. But if you're in a burn out contest or something, nothing will beat it.
