-   67-69 Suspension (https://camaroforums.com/forum/67-69-suspension-139/)
-   -   Definative 1st Gen camaro wheel alignment specs. (https://camaroforums.com/forum/67-69-suspension-139/definative-1st-gen-camaro-wheel-alignment-specs-75817/)
p3te Nov 17, 2013 11:35 AM
Hey, can anyone help with a street setup for my 1969 Camaro? I’ve searched the internet and forums and found a few setups but with conflicting information (here’s one I bookmarked Muscle Car Front End Alignment Basics - Super Chevy Magazine)
I’ve just changed my front tyres as the edges were scrubbed off, I’m running a cpp big block suspension kit up front including drop spindles, 215/45/17 tyres up front and I plan on changing the upper and lower ball joints and outer tie rod ends and a set of these to lift the front about 1" Camaro Coil Spring Spacer, Front, 1967-1981 | 3789664 - Ricks Camaro Parts
So first question[*] would I benefit from fitting the 'tall' tie rod ends and upper ball joints? Or just the normal spec ones?
And[*] what would be a good wheel alignment spec for my car to stop it eating tyres for fun and drive well on the street? I can’t fault the drive as it is now it’s just the scrubbing of the tyres.
When the suspension kit was fitted about 4 year ago by the previous owner it was set to 3+ caster and ¾- camber, 1/8 toe in
http://imageshack.us/a/img194/1141/oqsv.jpghttp://imageshack.us/a/img849/8576/1qsp.jpghttp://imageshack.us/a/img706/6603/tr0q.jpghttp://imageshack.us/a/img443/1404/fbrd.jpghttp://imageshack.us/a/img18/3297/9whd.jpghttp://imageshack.us/a/img7/2166/4eis.jpg
77thor Nov 18, 2013 10:06 AM
Read... FIRST GEN SUSPENSION
scroll down to alignment specs.
DeereMan Jan 13, 2014 04:32 PM
The stock 1st gen Camaro suspension geometry sucks. IMO, you should take a look at Ridetech front suspension kits. I would not waste my time with the factory control arms.
http://www.ridetech.com/store/musclecars/
