Can I give my 69 F-41 suspension??
I now have a 69 that needs some suspension work. I also owned a new 74 Z-28 and remember how nice it handled so my question is when I rebuild the 69 A-arm bushings etc does anyone make a rebuild kit that is F-41 spec that would fit the 69 as well as add the rear bar?? I have read a lot of the posts and there are so many options to choose from, I would be very happy if I could make the 69 ride and handle just like a 74 Z-28 did, it seemed to be a very well balanced but firm ride. Thanks!!
Second gen Camaro's handled better than the first gen's right out of the factory.
First gen's require a bit more to get them to handle as well... thicker front swaybar, matched rear swaybar, better shocks, Guldstrand modification, poly A-arm bushings, etc. all will help to get your Camaro to handle. |
The 69 Z/28 came equipped with the F41 suspension and quicker steering, so yes you can change yours over.
