67 camaro leaf springs... stupid question
just bought a set of the OER-RLS they came with bushings already installed on one end,, do the side with bushings go towered the front of car or are those the rear?
Measure from spring center bolt to spring eye.
The short distance is the front of spring. Compare with present set-up. BTW. The stupid question is the one not asked. |
The pressed in bushing goes in the front
The ones you install easily with your fingers, go to the shackles in the rear |
| All times are GMT -5. The time now is 06:20 AM. |
