1967 Camaro re with stance issue
https://cimg5.ibsrv.net/gimg/camarof...e88d067618.jpg
Purchased Camaro last year and noticed when I unloaded it the car was lower 3/4 inch on passenger side. When I got under it I could see the mono leaf was shot. Installed new coil springs in front and new multi leaf springs in back. Sat it back down on lift and it still has .75 lower on passenger side. Hoping for suggestions. I was wondering if the front eye of leaf springs are suppose to be torque or tighten and back off like a wheel bearing? I have sub frame connectors but I'm hesitant to put on until this is corrected. Any thought or ideas. Picture before new leafs |
But I bet once your butt is in the drivers seat, the car may be close to level. To make sure one of the leaf springs aren't preloaded, loosen the front bolts and the upper/lower shackle bolts, bounce on the rear of the car a few times with your body weight, and re-tighten.
As I look at the picture, to me, the rear window and gas tank appear parallel and level and body is leaning down on pass side?
It kinda does, doesn't it. Thinking panel replacement perhaps, and left side was installed a little high in back, or right side a little low?
If jousting the suspension like Camaro 69 suggested does not work there are 2 common issues that can cause this issue with a rag top.
