The Impossible 69 Camaro
I am not sure what else to call it, other than my impossible project. It was a 69 Camaro my parents had. I remember riding it a few times as a wee young lad. It was then parked in a farm field and the interior was stripped. I finally have a place of my own and space to work on it, so I dug it out of the barn where it had been eventually moved.
Specs as I know them now Rochester 2 barrel 307 V8 2 speed automatic The Bad The floor pan is shot. I mean you could almost run this thing Flintstones style. The trunk pan is probably worse, passenger side leaf spring is poking through the trunk. Tried pulling the pugs for giggles, Spark plug shank had rusted so bad that it broke and only the porcelain came out The Good Not much, I mean the interior was stripped so less crap to remove? Tentative plan is a resto mod, hope I can save it Here are some pics https://cimg1.ibsrv.net/gimg/camarof...c514a32c46.jpg https://cimg7.ibsrv.net/gimg/camarof...8bc2edc1bb.jpg https://cimg0.ibsrv.net/gimg/camarof...3cbd1085a2.jpg |
wow! what a find. it must be sentimental being it was your parents.
did you decide any more on what youre going to do? |
Thanks for the interest. I am going to strip it down and then have the shell blasted to see what metal is left. Here is a pic of current state as I get all the parts off. (yeah I know I went a little nuts labeling things, but I figure better to do that then be scratching my head later :) .
https://cimg4.ibsrv.net/gimg/camarof...7f2473e0e2.jpg |
Well We've seen worse resurrected, good luck and keep us posted. PS: I'd toss that boat anchor 307,not worth trying to save it.
Yeah the current plan is the engine and transmission are definitely going to get replaced. Going to stick with a small block of some type.
My approaching challenge is how to make sure the body shell doesn't flex too much when I remove the drive train and front sub frame. For now I am leaving the doors on to help. But going to look at the 4 jack stand method and see if its solid enough in those places to support it. |
Thanks to everyone for following along. Still plugging away. I am going to have to start finding places to put all the parts I am taking off. :)
https://cimg5.ibsrv.net/gimg/camarof...c18c52a28c.jpg |
Ok front clip removed, a few bits of wiring harness left to unplug... Trying to figure out what to tackle next. (And also where to put parts!! :) )
https://cimg5.ibsrv.net/gimg/camarof...194385bba4.jpg |
Just my opinion but if you are going to rebuild it you need a jig. This is a table that you use to set positions of feature to insure the car is flat and square. I would not be 100% sure its that way now. You really should look at a dynacorn replacement body, Every piece of metal I can see needs replaced. That is a lot of cost in replacement parts and a lot of places to make a mistake. The fire wall ties to the rockers and that is the most structural part of the car. If you send that car to be dipped in acid or blasted there will not be much left.
Originally Posted by Gorn
(Post 731624)
Dynacorn Camaro Body Shell https://cimg8.ibsrv.net/gimg/camarof...71cda411a6.jpg |
I watched a Car show one time were they interviewed a guy who owns a walnut blasting company. He said that about 15% of the cars he blasts get scraped. He said one of them was a 69 camaro that was bought as a driver off ebay. There had been so many "cover ups" over its 50 year life that after the blast there was not a single panel that did not need work. IMO walnut blaster will remove the least a amount of good metal with the exception of some of the rust dissolvers, I never seen anyone do a whole car in rust dissolvers. Problem with the dissolvers is that they wont remove dirt, paint or body filler.
