Game-Over Progression Thread
#72
as of JUNE
What needs to get done
i made a list and tried to prioriize...
im breaking it down into sections....
1. Leaf springs/ shocks, 6 body mounts, subframe connectors (can be done later)
2. Rear disc brakes/ lines on my 12 bolt.
3. Install 12 bolt rear
4. Change front drums to disc brakes, run new lines.
5. Replace my steerling box and steerling components (bushing, tierods etc)
6. Set up sending unit and install gas tank and run lines etc.
7. Install brake booster and hook lines up.
8. Clutch/ flywheel, tranny and assesories ( bolt ons, fast intake , rails etc) installed on block.
9. Pedal swap. ( auto to manual )
10. Install INSTALL kit for ls swap
11. Install motor and tranny
12. Measure and order wiring harness, then install when comes in.
13. Measure and order drive shaft, then install when comes in.
14. Install and wire radiator.
15. Install hedders.
16. Take to je in md for intake charge pipe and exhaust
17. Base tune
18. Start up and break in ( brakes, motor, clutch, rear)
19. Nitrous (?)
20. Tune.
17. Base tune
19. Nitrous (?)
20. Tune.
