morris classic concepts 3 point seat belts
In case you were not aware, the shoulder belt pivot points in the headliner may be covered by the headliner if the car did not have the useless factory shoulder belts installed. You just need to feel through the headline to locate the bolt anchor points for the pivot. Morris supplies all new bolts for the installation.
Perfect photos.. The install is very easy..... If there is any negative to this upgrade it's due to the low back factory seats and the fact that the belt can sometimes be high on the shoulder at the neck line. It depends on what seats (mine are stock at the moment), how far back they are (mine are all the way back) and the height of the driver which in my case is 6'. Its not a big issue since you can slide it over on the outside shoulder if it starts to rub at the neck line.
