Camaro 69 |
08-11-2013 12:43 AM |
Your backrest is adjustable from the factory. Lean the backrest forward, and look at the right rear corner of the seat. There you should see a rubber snubber, about the diameter of a quarter. If not, it's popped off and that's one reason why it's leaning back more. Then, bend over and look up at the bottom of the backrest, in the same spot where it would touch that seat snubber. There you will find, for lack of a better term, a bolt with a large diameter head. Screw that out till you get the backrest leaned forward more to the position you want.
