-   67-69 Interior (https://camaroforums.com/forum/67-69-interior-114/)
-   -   Accelerator pedal differences?? (https://camaroforums.com/forum/67-69-interior-114/accelerator-pedal-differences-68669/)
Moze Mar 15, 2012 10:43 AM
Hi, I'm new to the site and am currently restoring (for the past 12 yrs) my 69 Camaro. I have to replace the clutch/brake assembly and install a auto brake pedal. During this process, I was thinking of sprucing it up and adding billet pedals. While searching for gas pedals, I found a cowl induction and without cowl induction gas pedal. Can anyone tell me the difference in these? I never really looked or noticed what I have. The previous owner changed the tranny (but never changed the pedal assembly) and I am trying to make everything match correctly. Thanks
Moze Mar 15, 2012 10:54 AM
Also, does anyone know if they make an all aluminum brake pedal assembly like the accelerator? So far, I've only seen the rubber pad replacements.
Camaro 69 Mar 15, 2012 10:59 AM
The arms are different. With the stock cowl induction hood setup, the gas pedal arm has a tab on the side to mount the electric switch, that activates a solenoid, which opens the cowl induction hood flapper when the gas pedal gets mashed to the floor.
Moze Mar 15, 2012 12:59 PM
Ok cool. So is that worth it or make a big difference? I have a cowl hood, but it is always "open" I guess.
Camaro 69 Mar 15, 2012 02:18 PM
You only need that style pedal if you still have, or want to have an operational hood flapper.
