Accelerator pedal differences??
Old Mar 15, 2012 | 10:43 AM
Moze's Avatar
Default Accelerator pedal differences??
Hi, I'm new to the site and am currently restoring (for the past 12 yrs) my 69 Camaro. I have to replace the clutch/brake assembly and install a auto brake pedal. During this process, I was thinking of sprucing it up and adding billet pedals. While searching for gas pedals, I found a cowl induction and without cowl induction gas pedal. Can anyone tell me the difference in these? I never really looked or noticed what I have. The previous owner changed the tranny (but never changed the pedal assembly) and I am trying to make everything match correctly. Thanks
Old Mar 15, 2012 | 10:54 AM
Moze's Avatar
Also, does anyone know if they make an all aluminum brake pedal assembly like the accelerator? So far, I've only seen the rubber pad replacements.
Old Mar 15, 2012 | 10:59 AM
The arms are different. With the stock cowl induction hood setup, the gas pedal arm has a tab on the side to mount the electric switch, that activates a solenoid, which opens the cowl induction hood flapper when the gas pedal gets mashed to the floor.
Old Mar 15, 2012 | 12:59 PM
Moze's Avatar
Ok cool. So is that worth it or make a big difference? I have a cowl hood, but it is always "open" I guess.
Old Mar 15, 2012 | 02:18 PM
You only need that style pedal if you still have, or want to have an operational hood flapper.
jrgearhead
Jan 11, 2026 07:45 PM
tattoo400
Jul 19, 2012 11:24 PM
jasunf
May 3, 2010 10:46 AM
inter4life47
Oct 27, 2008 10:30 PM
Torque Junky
Jun 18, 2006 01:20 AM
