69 Ignition Key
Old 02-25-2019, 07:29 PM
Povs1969's Avatar
Default 69 Ignition Key
Does anyone sell a new ignition with a key that is made to match the original key code? In other words, I provide the code on the old ignition and they set the new ignition to match. Saves me from also changing the door locks.
Old 02-25-2019, 08:13 PM
Have you tried your local Chevy dealer? If no luck there check with a locksmith shop.
Old 03-02-2019, 10:37 AM
Not so sure what you want is available, I haven't seen it. What you can do is re-key the new cylinder to your old key. Take apart both cylinders, and replace the new brass slugs with the old ones. Or, you can insert the old key into the new cylinder, and file down the protruding slugs so they are flush with the cylinder like they were with the new key that it came with. If you're not comfortable tackling this, a locksmith can.
1augapfel
04-14-2013 10:51 PM
Roger3
10-16-2012 10:10 AM
dwb
12-13-2010 10:44 AM
eddiebj
02-27-2008 01:43 PM
Quick Reply: 69 Ignition Key
