1969 Dash Pad Question
I bought a new Dash Pad for my 1969 Camaro and there is two depressions on the lower edge just above the Speedo and Tach. Each impression is about 5-6 inches by 1-1/2 inches.
How do one add a picture??? Is becasue I am a newoob?
Those indentations are there on my factory dash too. Only reason I can see is so you don't see the two mounting screws in each one, unless you bend down and look.
Nothing mounts or fits up into the cutouts, if that's your main concern.
How did your doubler idea turn out. I just posted the same question, and then found yoyrs. I am considering the same solution. Thanks, Bob
