Vacuum can
Old Nov 18, 2007 | 03:39 PM
hipirn's Avatar
Default Vacuum can
Am restoring my 67 Camaro RS SS convt. 350 with air, that's been apart for 25 years.Where does the vacuum assist cannister for the HVAC mount? I knowit goes under the hood somewhere? Anyone have a photo of the placement? Thanks...Hipirn
Old Nov 21, 2007 | 11:42 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: Vacuum can
I cant find anything about a vacume assist canister. Are you sure you are clling it the right name? Do you have a picture of it?
Old Nov 21, 2007 | 08:59 PM
hipirn's Avatar
Thanks for the post cplthomas; I don't have a picture at hand but it looks like a 1/3rd of a quart sized juice can, that is it is as big around as a quart can but only about a 1/3rd as longand has a small hose connection on either end, it has a small bracket on it, one end goes tointake manifold vacum the other goes to the vacuum controled heater/airconditioning slide control in the dash.I suspect that air conditioned early convertibles are an oddity! Maybe that's why not many know about it, though I did see one mounted on an air conditioned Chevelle, on that application it was mounted to the to the HVAC unit on the firewall. The bracket on mine doesn't want to fit there! I took pictures of this stuff 25 years ago before disasembly unfortunatley they didn't survive poor storage.. hipirn
Old Dec 5, 2007 | 06:52 PM
1stgenssclone's Avatar
had my 68 left fender off today and you are in luck,
mine is behind the left fender well mounted to the fire wall and has a hose or two going to it,
looks like a small soup can.
Old Dec 5, 2007 | 09:36 PM
hipirn's Avatar
Thanks 1stgenclone. That is exactly where mine must have been, it's the only place on the firewall with holes that fit the bracket... Also I was rummaging around some old notes I made on tear down (25 years! ago) and lo and behold I found a diagram amongst them showing the same location as you describe... Mystery solved, thanks again....Phil (hipirn)
jcase350
82-92 V8 Tech
May 16, 2012 11:40 AM
kyles_81camaro
Apr 13, 2011 03:48 PM
twdavis61@comcast.net
May 14, 2009 06:34 AM
xPBxWrEckeD
82-92 V8 Tech
Nov 22, 2007 06:55 PM
95camz28
Nov 12, 2007 08:17 PM
