Upper and lower control arms
Old 07-26-2010, 10:03 AM
mpkoester's Avatar
Default Upper and lower control arms
All,
I need new upper and lower control arms for a big block 1969 camaro. I live in NM so finding rust free parts is not a problem. However, finding classic camaros is a problem. Were the control arms only made for the camaro or were they used in a wide variety of cars in the late 60's maybe early 70's? If so what years and models could I look for (cars or trucks) to find the right control arms to fit a 1969 camaro?
Old 07-26-2010, 10:46 AM
dynarider33's Avatar
Novas and Camaros shared the same subframe, and A-arm asembly. If you want it to be correct different years had the bump stop hole in different locations on the lower. As far as Big or small block they are the same.
Old 07-26-2010, 11:58 AM
shevrolay's Avatar
Are you looking to stay stock? Why not update to tubulars?
bluedeuce2
08-12-2014 08:46 AM
Scott Johnson
12-11-2012 07:28 AM
gagger84
07-01-2011 09:36 AM
shifty427
70-81 V8 Tech
07-16-2010 07:41 PM
mycarsux88
01-19-2008 08:56 PM
Quick Reply: Upper and lower control arms
