Torque Converter Cover Issue
I have a 69 with a 350 / TH350. Plastic torque converter cover is coming loose & rubbing on torque converter. Is it OK to remove & run until replacement arrives? Also, any tips to mount new cover to allow for adequate clearance? Thanks in advance.
Thanks for the info. The cover holes are worn so the cover does not sit in the exact position as designed. Also, 1 of the 4 mounting bolts broken off so there is play around that area. I'll look into the metal ones in the future.
MDThomas26
70-81 Transmission & Differential
12
08-26-2012 05:17 PM
MDThomas26
08-13-2012 06:31 PM
