Tic Toc Help
Tic Toc Help
I am installing an OEM tic tock into my 68 non tach car.
I need someone to give me direction on how to wire it up once i install it.
I order a new circuit board for the dash housing from N.P.D. part # C-9744-32B. I now have a 6" Autometer C2 tach mounted on my steering colume which i use and will keep there. So i want to know if i can tap into the C2 for the tach signal on the tic toc or do i need to run seperate wires to it. Also if someone can post the correct wiring diagram for the original tic toc i would greatly appreciated it.
Thank you very much
Ted
Thank you very much
Ted
so are you mainly wanting the tic toc tac for the clock? good luck getting it to work. I did the same thing with a brand new repop and i can never get the clock to work. got my tach working perfectly. Ill go look and see if i still have the instructions for it.
