Templete for a non gauge console???
Hey guys, my car did not come with gauges and I really want to upgrade/retrofit it but I want to keep the original console as opposed to buying a new reproduction one. Not so much for the money but I am replacing so many parts (sheet metal and crome) that I don't want to end up with a Chinese Camaro
Is it possible to cut out the non gauge console and do a good job so you can not tell weather it is an original gauge console or not, is there a templete for the job?
Thanks for the help and God Bless
![Icon Laugh](https://camaroforums.com/forum/images/smilies/icon_laugh.gif)
I wouldn't want to hack up the original console top, unless you're not worried about keeping the original one in tact. You might be better off trying to find a used one on ebay or at a swap meet, if you don't want to buy a repro. The gauge console has mounting tabs to mount the cluster to, something you would have to retrofit if you cut yours. If you plan on installing a factory style gauge cluster, you can use that as a pattern.
No template, according to the local Camaro Parts supplier. I would visit your local classic Camaro Parts supplier and ask if you could make a template off one of the consoles that have the cut-out. Then I would go to someone like "TAP Plastics" and have them professionally cut it out. If you do it yourself, drill a pilot hole first, then use a hacksaw blade. You might give "Rick's Camaro" a call, I did see in their catalog a gauge housing for non-gauge consoles, but do not know the details on how it worked. It may have a template that you use to cut the console.
